Removing windsheild washer resevoir
Any body how to remove the windsheild washer resevoir from a 86 951 ?
I was told from the bottom, but it sure looks tight ?
Andrew
86 blk / blk 951
Old 05-22-2006, 12:29 PM
monsterdog's Avatar
I tried this unsuccessfully a while back. I'll never try it again. I thought I almost had it after endless wiggling and yanking and knuckle busting and prying.
The headlight pump and steering lines make it a huge pain in the arse.
I was trying to get it out from the top though. The tank seems too tall to get it out the other way. I figure if you remove everything around it, you may have more luck than I. Just FYI, it's not very flexible at all.
Mine leaks a little about half way up around a seam on the rear inboard side if you're looking at it from underneath, with feet sticking out from the front of the car. I was going to try some kind of sealant, but wasn't sure what to use.
One thing I did find is that if you get the headlight washer pump out and give up trying to get it back in while the tank is still in the car, a tapered rubber and brass plug works well to stop that hole - you tighten the plug and the rubber compresses between two brass plates - they use them on boats and such.
___________________________________
1986 944 Turbo, 88k miles, Copenhagen Blue
Old 05-23-2006, 01:59 PM
windsheild resevoir removal
Thanks for taking the time to reply...so its not just me
I think I'll take your advise and leave it alone. Thanks
Old 05-23-2006, 02:04 PM
It comes out under the car and the cracks can be plastic welded.
Old 05-27-2006, 04:38 AM
Super Moderator
nize's Avatar
if it's the short one, it can come out the top. if it's the long one (the one that comes with the headlight washer option), it only comes out through the bottom.
Old 06-14-2006, 04:09 PM
