86 with rough idle
My car has a rough idle or more like a vibration (900rpm) which will smooth out if you bring the rpm's to 1100 or so. Once I'm driving it seems fine. Motor mounts check out OK. Any thoughts?
73 914-6, Vintage Spyder,05 997(sold), 04 Anniversary 911 #151(sold) 08 Beck Speedster #317 (sold) 76 911S (sold) 76 911 Targa (cut up & sold) 86 951 (sold)914-6 (sold) |
Super Moderator
are all of the cylinders firing properly at idle? i've seen this problem occur when there's a bad injector.
you can test this and locate the bad one by disconnecting one of the injectors at idle to see if it changes.
I'll give it a shot - but wouldn't I aslo have poor performance under load?
Super Moderator
not necessarily, because if one of the injectors is over-flowing, the resulting mixture would be too rich to fire at low rpm's but may be lean enough to fire at higher rpm's.
i've had a similar problem and discovered that the pintle (needle) on one of the injectors had broken off, resulting in a 50% overflow condition in one cylinder.
Thanks, it sounds like a good starting point as it does smooth out around 1100rpm & seems to have normal acceleration.
Mine has had a rough idle three times on me.
First time: Incorrectly adjusted TPS after I had throttle body enlarged and I reassembled. Second time: Bad distributor cap and/or rotor. This did not show up above idle speed. Third time: Bad idle stablizer valve. Symptom occurred when first started and cold. It was fine when warm. Vibration at idle: Bad engine mount. Vibration goes away above idle.
Turns out it was a bad motor mount. One side was crushed or flattened. Should be smooth sailing now.
