alex_cristocea's Avatar
Send a message via Yahoo to alex_cristocea
windshield washer problem
I have a problem with windshield washer.First it looked like it's loosing pressure for a few weeks then it has stopped.I removed the washer pomp, removed the electric motor, looked inside and found a lot of rust.I replaced the electric pomp and is still not working.
Does anyone now how to fix the problem or where to look.I looked in the service manual and didn't found anything that could help.
Old 07-31-2006, 08:24 AM
Super Moderator
nize's Avatar
you may have some clogging in the water lines. try running some alcohol through it and see if it helps clear the clogs.
Old 07-31-2006, 11:20 AM
sorry I forgot to mention that I powered the pomp directly from battery and splashes ok.The problem is that I don't have power on the pomp plug when I pull the splash lever.Does someone have an troubleshooting schematic?
Old 07-31-2006, 12:08 PM
Super Moderator
nize's Avatar
hmm, fuse okay? i've never had to troubleshoot my washer motors.
Old 07-31-2006, 12:23 PM
I don't know witch fuse is, on the fuse panel is not mentioned any fuse for windshield washer motor or relay.I've checked fuses - all ok.I already posted on reenlist
Old 07-31-2006, 12:27 PM
Problem fixed. It was the steering column switch. Thanks for help and sorry for the five year delay .
Old 02-20-2012, 01:17 PM
Quality
phoenix_iii's Avatar
Better late than never...
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 02-22-2012, 05:21 PM
