944 turbo speedo sender
ok, just had a track day up at bedford autodrome (my first track day, f***ing awesome) and my cv joint bolts got completely sheered off which was fun, could have been worse, however now my speedo isn't working, i'm guessing this is the speedo sender on the gearbox, can anyone tell me... i've found one on the internet and i just need to know if the sender is different from non-turbo 944's as it just says its a sender for 944's 86 onwards.
Old 08-30-2006, 12:44 AM
Had the same thing happen to me but on the hightway. Driver side CV joint separated at tranny. The half shaft can extend and hit the speedo sender that is mounted on tranny. My sender was smacked off by the halfshaft. Got a used one (sender) from PartsHeaven. If the bolts on CV joint loosen, they get more loading and will shear or completely back out like mine did. Half shaft also took a chunk out of my tranny.
Partsheaven has a warranty on their used parts and are good people to deal with.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-30-2006, 03:21 AM
thanks for the reply dude, unfortunatley im in the uk so can't use Partsheaven but do you know if the speedo sender is the same on the turbo as it is on the normally aspirated 944's?
Old 08-30-2006, 03:19 PM
Check this website to see if it's the part you need. There is also a picture of the part. Speedometer transmitter....same for both according to this website.
http://www.********.com/OEMParts/porsche.asp
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-31-2006, 03:32 AM
