Vacuum Lines
![]() This Vacuum Line is near the throttle body. Where do i plug it in? ![]() This end's near the fuse box. where does the other end go?
My cars for sale, due to move 1986 944 turbo - For sale. 1987 944 N/A - For sale. |
Lowell 1988 944 Red Project car (Now daily driver, Daughter's to school ride) 1983 944 Grey NEW Project car http://www.pelicanparts.com/gallery/tnporsche |
I did -- I found the vacuum line one for the fuel thingies -- Should show most of the vacuum lines, however, I can't identify the parts it's labeled...
Can anyone translate? IE - Blow off valve isn't there, but a vacuum line is run from thanks, -Alex
should be two connections on the right side of the throttle body. if both of those are covered, there is also a t underneath with a line that runs up to the location shown near the fuse box
life is participation in evolution 87 944 racer . PRO44 #1 01 986S endurance racer 93 968 coupe 6spd |
Yes, the T connection can be hard to locate along with the line that runs up to there. Especially with a leak and a bad fuel damper causing your hands to be soaked with gasoline. Ask me how I know.. :-/
M |
