Dies
After driving for awhile the car just dies, all lites work just the engine will not run. after a few minutes or so it will restart and run normally again.
Any help would be apreciated
1983 911SC 1977 911S "parting out" |
Sounds like a fuel problem. Blocked filter or dickie fuel pump.
Dave Jezza http://www.pelicanparts.com/gallery/jezza944 1984 944na Krystalgrun (Crystal Green) |
Is this a 944? If so resolder the DME.
Yesa a 944 non turbo and the last year before anti lock brakes
resolder the DME? do you mean one of the wires going in or out or inside the DME circuit board? do you have a picture? Its my bosses car.
Search here for resoldering the DME.
Other heat/time related problems are the DME/fuel pump relay and the speed and reference sensor connectors. Also read all of www.clarks-garage.com .
