rudidelange's Avatar
Overhauling calipers - you can use these parts
In the process of overhauling my 83 Euro spec rear calipers I found that a Peugeot 305 (70's - 1980's model) uses the same brake pads and that the sealing ring (36 mm internal diameter) inside the bore of the rear caliper is the same as is used in a Volvo 144. The sealing ring in the overhaul kit from our host was too thin and larger than the 36mm required for my Euro spec car.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 11-07-2006, 07:08 AM
SoCal Driver's Avatar
Gotta use what you gotta use. Cut up a leather belt if necessary.
Get the Euro spec PDF's from Porsche's web site to find your parts numbers.
Old 11-07-2006, 10:35 AM
