Right I've had enough of this Temp gauge flicking lark!
I'm assuming now that it must be the earth in the gauge as when I tap the dash it returns to normal at times. I've cleaned all the other earths I can find. So, how easy is it to get to the guage rear to clean it all up and redo the earth? Please bear in mind that its an S2 Cabriolet!!! Thanks Pat. |
As always clean all of the grounds between the engine and chassis and battery. Also clean the red wires at the battery's positive terminal. Clean the grounding connections for the gauge cluster.
It's not difficult to pull the cluster...just a few screws. Takes about 10 minutes. There is also an article here in the tech section which talks about what to clean when you get the cluster out.
I had the exact same problem. and it was a ground. For me it was the ground that goes from the rear of the engne. Coming off the bellhousing to the firewall. On the bell housing ground you will see 3-4 brown wires. One of those was a lil loose and caused the same problem you have now. Taping the dash and everything
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
I've cleaned what I think is all the earths, including the engine to firewall and its still at it!
So it hell for leather at the dash this weekend. Thanks for all your help. |
