Loss of *ALL* power
Driving along, the radio shuts off and turns back on. Whatever, keep driving.
Little later, stopped at a stoplight, and my car shuts off. Try to turn it back on using the key, no click, no lights, no sound, no power. Try to turn on hazards, no dice. A few seconds later, my headlights fold back down (key was in off position) Power must be back on! Turn the key, sure enough, starts right up. Radio doesn't work anymore ![]() Gremlins? Is there a self cylcing breaker switch? Any ideas?
My cars for sale, due to move 1986 944 turbo - For sale. 1987 944 N/A - For sale. |
White and Nerdy
Voltage meter reading high or low?
Shadilay. |
low -- at 12? I think....
I am guessing that it's just a bad electrical connection on the battery or the starter. The car's main power comes from those two sources. Also check the main ground cable on the battery and where it attaches to the back of the block.
meister member
sounds like the alternator.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Could be an alternator...but when he said it would shut off and then start right back up a few moments later, that led me to believe that the battery was still charged but wasn't getting power to the car for a short period of time. One other possibility I thought of later was the possibility of a switch key.
White and Nerdy
Shadilay. |
meister member
my alternator was only putting out 11.5 -12.0V so things would intermitently work. Headlights would some times go down, car would not start sometimes, all sorts of goofy things. At around 12.0 volts it seemed like things just would work like they were suppose to. I took my alternator off and had it tested at Autozone and it confimed what I saw with my meters.
Speedy
Well it wasn't like my car died, and I couldn't start it but my headlights were on.
ALL power was off. Headlights when off, all lights went off, stereo off, ignition off, it was like someone took my positive battery terminal off, then put it back on 30 seconds later.
Check your cables, start at the battery and work out. Check all ground connections. Welcome to Porsche........creators of magic electricity.....
Jon |
