speccar's Avatar
Spoiler question
Is there an override for the rear spoiler on a 2000 996 Cab so it will stay up all the time?
email [email protected]
Thanks,
Mark
Old 12-07-2006, 01:06 PM
450knotOffice's Avatar
There is a rocker switch down in the driver's side footwell on the left sidewall. It's actually on the bottom of the fuse panel. With the ignition on, if you momentarilly press the upper part of the switch, the spoiler will rise. If you press and hold the lower part of the switch, it'll lower. However, I do not believe it's permanent. I think it'll recycle itself once you run the car and then shut it down again.
Old 12-08-2006, 09:53 AM
