WPOZZZ's Avatar
996 n00b
Actually, I'm a Porsche n00b as I have had nothing but BMWs for the past 18 years. Bought a 85 Carrera cab a few months ago and just bought a 99 996.
For some reason, I can't get my remote locking to work. I push the button on both keys and nothing. I have to lock the car with the key. Is there a way to program it yourself, or do I have to take it to the dealer?
As with all n00bs, one must post a pic, so here she is.
Old 12-09-2006, 07:53 PM
AFJuvat's Avatar
Try changing the battery in the remote first.
Otherwise, it needs to go to a repair shop that has a PST-2 or PST-3
AFJ
Old 12-10-2006, 06:11 AM
450knotOffice's Avatar
One thing I've heard of is the car going into some sort of sleep mode if there has been a long period of inactivity in order to conserve the battery (five days). The key-less entry system disables itself. Apparently you need to unlock the doors manually and then try the key fobs again. I've heard that usually works. It happened to me once after a vacation, so I unlocked the car manually. Afterward, the key fobs worked normally.
Another thing is that these cars are infamous for not being to arm or disarm the alarm from greater than about four feet away. I'm not kidding. There is a fix that you can do at home that basically removes some unnecessary shielding from around the antennae wire in the drivers side A-pillar. Do a search on the Rennlist 996 forum and you should find a link to an article that shows you how to fix that problem. I bookmarked it but haven't actually taken care of the issue yet. Here's a link to a thread that should lead you to the article.http://forums.rennlist.com/rennforums/showthread.php?t=311755&highlight=key+range
The fob might also just need a reset. Here's a link to a Renntech thread that detailed how to reset the key fob. You may need to register first. http://www.renntech.org/forums/index.php?showtopic=7409&hl=key+fob
Old 12-11-2006, 10:26 AM
Lightbulb
Go see Chris at Air-Cooled 591-8222, he is off Young street in Honolulu. Chris will have that car running tip-top for you.
Aloha
Old 12-11-2006, 03:38 PM
WPOZZZ's Avatar
Thanks, Kailua. Both cars are running great. I'm ordering a Durametric so I think I'll try that on my locks first.
Old 12-11-2006, 11:49 PM
