Code P1130
2000 911 Turbo. Has anyone had issues with this code? The check engine light keeps coming on. Has been to the dealer 3 times and still not fixed! I read the codes myself and this is the current code. Thanks in advance,
Christian |
\\edited by moderator\\
AFJuvat
1999 Porsche 911 Carrera (996) Last edited by AFJuvat; 03-19-2007 at 07:31 AM.. |
Did you find out what the code was?
1999 Porsche 911 Carrera (996) |
I'll look up the code this evening.
2001 996 TT
P1130 Oxygen sensing adaptation, idle range, bank 2 (cyl 4 - 6 below limit. Possible causes: Faulty MAF sensor Faulty fuel pressure Fuel injector leaks Air intake leaks exhaust leaks AFJ
Thanks for all the help! I'll investigate further.
Christian |
