Porsche Crest Aftermarket Headers For 996
Does anyone know if aftermarket headers for 996's truly give any hp advantage over stock?
They come from the factory with headers already. Most aftermarket headers claim 12-15hp gains. Any input would be appreciated.
Old 01-25-2008, 01:31 PM
earlyapex's Avatar
The 3.4L engines will see some benefit, but they should the chip reprogramed. It's an expensive proposition for relatively small gains in power.
Eric
1978 spec 911
1998 C2S
Old 01-27-2008, 06:29 AM
I don't think you can get those numbers by replacing the headers alone. I do know the OEM x51 manifolds/header have the larger openinings and are standard on the "S" models. I just purchased a set from a member on this forum, however I haven't mounted they yet.
Old 01-29-2008, 08:39 AM
Send a message via AIM to Chuck Jones
When I had my 996, I dumped close to $5K into mods...headers, mufflers, RSS plenum, PSS9 suspension, GIAC flash, EVO CAI, etc....and I'll bet I didnt' pick up 35-40 HP. I still had trouble going against Mfletch who was running a few mods in his Tip.
The 3.4 L engine doesn't have much room for HP increases....especially if you just do one or two of the mods. The performance comes from all the mods working in concert....and sometimes, the mods work AGAINST you. I've seen instances of where guys post that the mod actually resulted in a reduction of HP based upon dyno info. Do your homework before you start down that mod slope....knowing what I do now, I wouldn't have done nearly as much as I did.
Now the TT is a whole other matter....it sucks up mods for great gains.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 01-29-2008, 04:03 PM
