rear camber issue
I have been an issue lately with my cab eating up the inside of the rear tires. My latest set of hard compound tires only lasted a little over 10k miles. The tire place told me that these cars are cambered for the race track and that is about all I'm gonna get from rear tires. I don't like that response. I had them check the camber and they adjusted it a little more, but they're recommendation is to fill up the new tires with nitrogen also. Any ideas???
E |
Our customers get anything up to 15k from Michelins rears.
What size wheel tire combination are you using? Stock or modifed suspension? Street or track alignment? What brand of tire? Does your alignment shop understand Porsche vehicles and what type of alignment equipment are they using. What does your Porsche repair shop say about this? Nitrogen won't change tire wear.
You can always change your alignment. Maybe the previous owner had it set up for some aggressive driving. Have your local dealer check the alignment.
Scott
1988 Porsche 944 Turbo S 70,000 1987 Porsche 911 107k (sold) 1982 Mercedes 240D 4-Speed (mileage unknown) 1998 Mercedes E300 Turbodiesel 147,000 (sold) 1985 Mercedes 300D 227,000 (sold) |
Thanks for all the good information guys. Yeah, I didn't think Nitrogen would have much of an effect on tire wear, but it couldn't hurt. At this point, I have it cambered down to the least aggressive stance. My Porsche dealer said it is normal for them to eat up tires. I guess that's the nature of the beast. My plan now is to rotate left to right at 5K miles. That will bring the inside to the outside and may extend life of the tire a bit.
Thanks again... E |
Depending on your tires, you probably won't be able to do that as some are inside/outside only and directional.
Hence, your rear right is always your rear right. Cheers Aaron |
