Check engine light popped on
I have a '01 996 cab, and during a short drive today, the check engine light came on. Any self maintainace things I can check? Will it re-set itself, or can I re-sent it. The manual says it's still OK to drive. Correct? The cars feels fine. No smoke, no bad idle or rough engine at any RPM.
Thanks!
Old 11-23-2008, 09:00 PM
Banned
Post Good health
bump up ..--------------------------------very good site:buy Women's ugg boots, Uggs boots, dog bed, pet supply, pet product,
Old 11-29-2008, 10:08 AM
O2 Sensors would be a good start...
I'd get the durametric setup it pays for itself many times over.
Cheers
Aaron
Old 11-29-2008, 01:37 PM
Had same problem with my '99 996. Smoke test of the engine revealed very small vacuum leak which was easily corrected (although a little spendy).
Old 12-01-2008, 08:51 PM
Quickest easiest is to check the gas cap, is it tight, is the seal good?
Old 12-02-2008, 06:13 PM
ischmitz's Avatar
The same guy posted his fault code here http://forums.pelicanparts.com/showthread.php?t=443140 a couple of days later. So apparently he has at least done his first step towards a fix: DIAGNOSIS of the problem.
I don't think random guesses will add any value here. If a fault occors that triggers the CEL you need to read out the fault code(s) and then work from there. A CEL can mean literally hundreds of different things. Shotgunning will not get you anywhere. It's like saying: "I am in pain" and someone answering:"Hey, my bro had pain too a couple of years ago and it turned to be an ulcer. Try drinking lots of milk and you might be fine" ......
(sorry, couldn't help it)
Old 12-02-2008, 08:38 PM
Ya well, least we were trying based on the limited information. I did say to get the diagnostic tool!
A
Old 12-02-2008, 08:44 PM
