Pelican Parts Vendor
Rennline's Avatar
Rennline Front Tie Down/Jack Plate **Product Release**
Securing a 997/996/Boxster or Cayman to a trailer is next to impossible without the use of wheel straps that are just about guaranteed to destroy your wheels in time. Save those expensive wheels with a set of inexpensive tie down hooks from Rennline. These hooks have been specifically engineered to bolt to the front of your car without any modification or removal of any factory torqued bolts. Another great feature of these hooks are that Rennline has incorporated a much needed jack pad that will allow you to easily lift the front of your car without the worry of damaging your rocker panel or plastic under trays. Hooks are constructed of steel and powder coated red. Each kit comes with (2) front hooks and all hardware needed for a 5 minute installation.
To purchase this item please click here!
Old 01-09-2009, 03:54 AM
Cayman Tie Downs
I ordered the front and rear tie downs for my 2008 Cayman S. They all installed well except for the front right. There is a vent hose that was in the way so I had to modify the tie down by drilling a large hole in it and then used a hack saw to open up the hole.
Old 07-29-2026, 11:01 AM
