Intermediate shaft's bearing
Hallo to all,
I'm the owner of a porsche 996 carrera4 since 2000 year.
I'm experiencing troubles with the intermediate shaft's bearing.
I have to replace it with another but porsche doesn't sell it alone; instead I'm forced to buy all the intermediate shaft, that during years have been modified in such way that today I sould replace also the main shaft...in some words a lot of money just for a little bearing.
Anyone can help me, please?
Thanks a lot in advance
Old 03-29-2009, 07:19 AM
I have replacement bearings and a method for changing it with the motor in the car. contact me for info
Dan Jacobs
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
Old 03-29-2009, 03:23 PM
Assuming you are refering the Intermediate shaft housing at the flywheel end of the case, this is the part that leaks oil into the clutch housing.
The IMS housing/seal assembly was updated, Porsche sells it and most shops replace it when changing RMS as well as installing the updated case bolts.
You need the intermediate shaft housing 996 105 017 02 (up to engine number 661 14164) , updated case bolts 4 x 999 385 0004 01 (long) 3 x 900 385 275 09 (short), the tensioner crush washers, updated rear main seal (factory part only), eight flywheel bolts and six clutch pressure plate bolts.
If the clutch and flywheel require replacing, there are also updated release lever parts to be installed.
Last edited by Britwrench; 03-30-2009 at 10:45 AM.. Reason: More information added.
Old 03-29-2009, 06:43 PM
There are redesigned updated parts available from after market folks
Jake Raby at
http://www.flat6innovations.com/
And L&N Engineering
http://www.lnengineering.com/store/catalog/boxstercayman911-models-c-36.html
Old 03-31-2009, 06:29 PM
Thank you verry much,
I had a look...really interesting stuff.
LNengineering told to me that in a couple of months they will release the retrofit kit for double row bearings shaft, like mine, wich permits to change the bearing without disassembling the engine.
Old 04-02-2009, 04:25 PM
Dan Jacobs
How can I tell if I need a new bearing and whats the cost. I own a 1999 996 C4
Old 09-07-2010, 10:32 AM
What sthe price for the new bearing I own a 1999 C4 996
Old 09-07-2010, 10:34 AM
basically when the bearing needs to be replaced the valves will hit the pistons and the engine will stop. after that you will probably need to replace the engine. LNE sells a replacement bearing for around $600 check the site. Intermediate Shaft IMS Upgrade and Retrofit Kit for Porsche 911, Boxster, and Cayman models
Many folks replace good bearings to have peace of mind.
Old 09-07-2010, 12:24 PM
You can't tell if your bearing is starting to going bad without dropping the transmission and pulling the IMS flange. The cost for the bearing & flange is around $600. Labor will be another $1K, unless you do it yourself.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 09-07-2010, 12:26 PM
