'01 Turbo, '89 Speedster
'01 Turbo that needs help!!!
Hi and Thanks in advance!!
I just finished a couple of updates on my '01 turbo such as, light weight Fidanza flywheel. New aftermarket Recirculating air valves, new O2 sensors, aftermarket headers and a ECU upgrade from Jet Performance.
All back together and go to start it with Programing the ECU with turning on the key (motor not running) for 60secs as my manual states. Off for 20sec, then start. It starts up fine and I hear it booting up as far as idle goes and such. It idles as it always has and test the clutch as it sounds great also. I let it run for 10min or so and go to rev it up a bit and nothing. I turn it off and try it again, starts perfect idles perfect but no revs. I do it again, this time I press the gas as I turn the key and it rev's to where ever my foot is into the gas and dies back to a perfect idle. So only when I start it with the gas it sounds great and dies back to a idle. Can anybody out there maybe suggest what I did wrong?? Thanks again, Bill
Old 04-19-2009, 04:45 PM
Shot in the dark.. MAF?
A
Old 04-20-2009, 10:32 PM
Send a message via AIM to Chuck Jones
Sounds like your ECU may have a programming glitch in it...since you have e-gas, it seems likely that it's not accepting the signal to increase gas flow as you depress the accelerator.
Can you back out the ECU programming back to stock and see what happens? Then reload it and hope for the best....like rebooting your computer.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 05-18-2009, 08:27 AM
