03 996 Oil pressure question
Hello,
This is my first post. The Oil pressure reading of our 03 996 C2 (3.6liter) is a little weird. When the car was idling, it was around 2.5bars on the oil gauge. When the car was cruising on the highway around 60mph, it was 5 bars. According to the owner's manual, @5000rpm it should be 3.5 bars. Should I be concerned about these readings? Just curious, what are the normal readings on the oil pressure gauge (idling and cruising)? |
Motul 5w40 I get 1 bar at idle when warm, at 5000 rpm-ish I get 4-4.5 bars. More RPM = more oil pressure.
Depending on the oil you run, I'd say you're fine. A |
Your oil pressure is going to be on the high side when you use a 0W-40 oil. Not to scare you or anything but you may want to do some reading about oil on the 911 BBS.
FC '73 911 Track Car '99 996 Daily Driver '93 968 Wife's Car '05 Cayanne S Family Car |
