996 faults
I have an intermittent problem: the ABS and PSM fault lights come on simultaneously, followed by failure of the cruise control.
Turning off the ignition clears everything, which then appear to work correctly for another 1000 miles +/-. What could this be? Thanks in advance.............. David |
Moved to 996 forum...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Un Chien Andalusia
I had a similar problem caused by a failing brake light switch on the pedal cluster. I think there's a write up on it on this forum somewhere...
http://forums.pelicanparts.com/showthread.php?t=366950 ... there you go. I hope that solves your problem.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD Last edited by Aerkuld; 08-17-2009 at 08:10 PM.. |
