996 short shift
I have a 2001 996 cab. I just drove my friends 03 turbo. The shifting is substantially shorter that the 01. Really nice.
Can I get that same shift? Is there a short shift kit like on the early 911's? Has anybody done it?
1978 911sc Targa Sold 2001 996 Cab Sold 2006 Cayenne S Silver Wifes Car for sale 2011 Jeep Wrangler Silver for sale 2010 Toyota Prius Black for sale 2016 BMW 328D wagon |
Yes there are different ones to choose from. I like the b&m or the factory short shifter.
I'm in the middle of installing a SShift in my 2000 996. It's a B&M knock-off from ebay. All was going well, using B&M's inet instructions until I began bench- assembling the new parts into the porsche carrier. First; the chrome handle rattles in it's (red part) carrier. There are 3 washers that appear to be there to prevent this but maybe more needed? Second the handle is angled toward the driver not away as the stock one is. Third; the nut does not clear the plastic carrier. It can not be simply disassembled as the cross bolt is pressed in. Anyone done/seen this? jvm
As stated, you have a number of options. From cheapest to most expensive:
1) ebay knock off - jvmcnair's post should tell you why you should avoid these. Option 2 is just as cheap if you buy used. 2) B&M short shift. New $200 used $100. I just sold one for $100 because I didn't like the notchiness and the very high effort when cold. I daily drive my 996 and I felt it was slowing me down. 3) Porsche supplied - apparantly these are mde by B&M for Porsche, but the it's a different design somehow. This may have been what your buddy had in his Turbo...keep in mind that the Turbo trans is different from the NA 996 trans...and this may affect the shift feel. $400-ish is what I've heard. 4) 997 stock shifter - $400-ish used. Some say the 997 shifter is a perfect blend of stock and short shift feel. 5) 997 sport shifter - $500-ish - a sportier (shorter) version of the 997 shifter. 6) cup shifter....very sporty...probably not great for daily driving...but that's a personal thing.$1000? The real upgrade apparently is to install cup cables at a cost of around $2000. These have metal ends rather than plastic ends which are used in all store bought cars right up to the GT3RS. The metal ends apparently feel rock solid. I personally went back to my stock 996 shifter and I'll probably stay there. I did swap my trans fluid out for a stickier mix of redline oils which improves the feel. Damn - just noticed this thread is 3 years old.
