summer tires vs winter time
My 2002 c4s is sitting in the garage. It has conti summer tires. I've noticed that during these cold times the tires will be flat spotted. Can i still drive the car in winter with these tires or will the flat spots not work themselves out when i drive it? Any other known problems with summer tires being used in the winter?
Old 01-08-2010, 04:47 AM
racer's Avatar
One issue with many summer tires in winter (cold) conditions is that the tire hardens up and doesn't give a very good ride and traction can be worse. Flatspots should work themselves out.
You could always put a few extra pounds of air in to help with flatspotting and or pressure loss. IIRC, each 10 degree drop in temp usually means a 1psi drop in your tires. Assuming no leaks, if you last checked your tires in 70 degree weather and now its 20 degrees, thats a 5 psi drop for your tire.
Past:
Old 01-08-2010, 07:02 AM
I have the same tires - the spec's say that anything below 7C and the tires are as hard as hockey pucks. At this temp point or below, the rubber won't warm up and unless you can put up with the thumping until they warm up at highway speeds I would change to winter tires. There is also the lack of grip because the tire compound has not been designed to operate at such low temps's - not enough silica in the rubber to remain flexible.
I store my car on rubber mat's - about 2 inches think under each wheel with 50psi in the tires when I park it in Nov. By the 1st or march when I pull it out it will have about 40psi all around I suspect.
We haven't had a lot of snow this year but without PSM or TC options and along with fools in lowered Honda's flying around without snows on - I don't need the hassle of someone hitting me. Besides, my car has never seen snow and hence - SALT, so I'm not starting now.
1999 996 C2
Old 01-28-2010, 04:39 AM
