Oil Guage Problem
Car: 2002 C4 Cab with 67,500
The Problem: While driving, the "oil failure" warning light comes on and the oil pressure guage drops to 0. Occurs randomly, no association with leisurely driving or going fast. Lasts about 10 seconds then returns to normal. No perceived mechanical changes while this occurs. My mechanic drove the car and couldn't get it to occur. Does this sound like a sensor problem, or is the oil pump starting to go on me? Thanks for the input! Mark
Author of "101 Projects"
I had the same problem on my 959. Whether it's a 959 or a 996, you still want to make sure it's the sensor, not the engine. So, I replaced the sensor. It's pretty easy to do - it's in the engine compartment - I have a tech article coming out on this soon. Definitely replace the sensor first (it is actually the same sensor that is used on the 959), as these fail *all* the time. We sell a ton of them.
-Wayne
Wayne,
Thanks for the advice. My mechanic thought the same thing. Any idea when the tech article would be available? Mark |
In a month or so. It's fairly easy to replace, but I can't recall how the access is in the 996 engine compartment.
-Wayne
Un Chien Andalusia
I agree with Wayne that failures of these seem relatively common. Mine does it at odd intervals and I take the wires off and clean the contacts. It will be fine for months, then it will start doing it again. I don't know whether it is a bad connection or whether the sensor is really playing up. I should probably buy a new one...
Here's a pic from the book (shows the replacement of the Boxster one with the 996 one).
