Unlock trunk
I locked my 99 / 911 with the remote key. The car had been sitting and the battery is now dead. I used the key to unlock the door manually but the trunk remains locked. I'm trying to find another way to unlock the trunk to get to the battery..............help!
Old 03-22-2010, 05:25 PM
If you pull the fuse panel located by your left foot, you will see the spot where you apply 12v to pop the trunk.
Old 03-23-2010, 08:27 AM
I called the dealer and they said basically the same thing. They recommended pulling the fuse at C3 (row C, 3rd from the left) inserting a wire jumper. Connect a 12v power source to the wire and ground to the frame. This would activate the security system to release the trunk. Would a battery charger be a suitable 12v source? Are we talking about the same spot / fuse? Another way is to pull the passenger wheel and loosen the inner fender and behind the head light is a manual pull ring to release the trunk. Your suggestion looks like the quickest route. Thanks Bob A
Old 03-23-2010, 05:20 PM
