Check engine light bulb
CHECK ENGINE LIGHT BULB
Called Porsche and they don't know which bulb I need to replace the CHECK ENGINE LIGHT BULB:
1 1/2 Watts?
1.2 Watts?
3 Watts?
I don't want to remove the cluster yet so I can drive it to the dealer to get the part or order it online..
Help!
Old 03-31-2010, 09:15 AM
Jamikest's Avatar
I am assuming you have a 996...
The cluster is held in by 2 screws. It takes an experienced tech approximately 45 seconds to remove the cluster. Just remove it, and the bulb. Then you will know what wattage bulb it is.
Old 03-31-2010, 06:04 PM
Thanks, doing it right now hopefully in less than 45sec. Starting... now!
Old 04-01-2010, 12:14 PM
Oh man! I thought you're on rennlist so i posted there...
yes it was pretty easy. Thanks!
now it still won't pass smog... I was wondering if it is possible to pass smog with a K&N cold air intake or if there's anyway to cheat the sensors?
Old 04-02-2010, 10:37 AM
