parts for engine lid shock?
Hi all,
First post here.... I have a 2001 996 cab. (Orient red / grey if you care!).
The engine compartment lid is no longer staying open.
I've ordered and received a new lid shock (from pelican - awesome service!).
In my researching the problem I learned that the 996 uses one shock, but the 996 turbo uses two. My shock is mounted on the engine compartment's right side. On the left side I see the same mounting holes (but of course there is no second shock mounted in a 996).
So my strategy is to add the second shock (on the left) to my car because that looks more straightforward than unscrewing the hard to get screws / connectors of the existing (bad) shock on the right side (they can only be reached from underneath).
Here's my question: What are the part number(s) for the screws or whatever attachment hardware is needed to mount the engine lid shock (to the left side if that makes a difference)? I don't see that in the pelican parts exploded diagram.
Thanks!!!
Old 04-18-2010, 02:09 PM
Pacific996's Avatar
Use a search term gas-filled strut or E_996_KATALOG.pdf is what you should be looking for.
The lower pin is one of the two listed below. All you have to do is call, email or write a parts department and they should help get the right stuff. Yah they should but good luck.
999-167-049-02 ball pin M 6
999-167-042-02 ball pin M 8
The M6 and M8 might mean milimeters for the bolt so maybe know the bolt sizes.
It also appears the strut is on the left not right so maybe years are different.
Pelican Parts - Product Information: OEM-99916704902
Pelican Parts - Product Information: OEM-99916704202
Old 04-19-2010, 02:17 AM
Author of "101 Projects"
Wayne 962's Avatar
Early 911s sometimes use two shocks in parallel. If I were having problems with a heavy decklid, I would probably look to double them up...
Yes, those appear to be the correct upper / lower pins...
-Wayne
Old 04-19-2010, 03:14 AM
Jamikest's Avatar
FYI:
You know the old shocks pop right off? There is a small release tab on the end of them- lift up and it comes right off. No need to unscrew fittings.
Old 04-19-2010, 09:30 AM
Wayne 962's Avatar
Originally Posted by Jamikest View Post
FYI:
I have an article coming out on this next month. Man, I need to get this stuff up on the web!
-Wayne
Old 04-20-2010, 12:48 PM
It looks like you have to tap the threads in the upper mount. I've already ordered my parts and received them from Pelican, but found that mine does not have threads in that mount.
Old 05-26-2010, 02:21 PM
