GT3 Brake Squeal
Hello
Just purchased a used 2004 GT3 with 12000 miles. According to the dealer the car had never been tracked or raced. The vehicle is showing the appropriate wear for a vehicle with this amount of mileage, i.e not a lot. I don't think the pads have been changed but the brakes squeal at every stop. I have always been light on the brakes, don't jump on the "brake pedal" but provide a light even pressure. What are my options beyond purchasing a new set of pad. The squeal is loud and as said, happens with every stop. |
Try the fun cheap solutions first, while the brakes are cold try to wash away all the brake dust where the pads contact the rotors with a water hose & then drive the car & brake hard to try & "deglaze" the pads & rotors.
+1 on BY's answer. I had some squeal when light on the brakes. When I wash my car,I spray down the rotors to wash out all the built up brake dust. This helps a lot.
If you blow the rotors out w/ air first then flush w/ water then drive them dry that works pretty well,
additionally put a slight chamfer on the leading edges and lube the guide rails w/ brake paste when all else fails try a softer pad like Pagid blue or Textar oems(996-352-949-03)
All
bought a set of the "Anti-Squeal Pad Inserts, Set Of Eight" from Pelican - all brake squeal noise is now gone - less than 1 hour to do front and rear using the Spring Clip Brake Tool for GT2/GT3, also from Pelican. Couldn't believe how easy to do - quickest brake pad removal and reinstall I have ever done. |
