996 gearbox swap?
Has anyone installed 02 or later 996 Gearbox in earlier 996?
Old 10-26-2010, 11:27 AM
Yes. Interchangeable. 2003 gearbox in 1999
Old 10-26-2010, 01:35 PM
any chance of offering the details on the swap
I do understand that the exterior dimensions are slightly different. I have been told that "it isn't possible". I have an opportunity to get a later box that is in excellent condition.
It would be very much appreciated to find out how this swap was done, especially the "problems" you encountered. thanks for responding, that itself was a treat-Mark
Old 10-27-2010, 06:34 AM
Mark,
Can't comment on your source of info. Just that I have actually done this on my car.
I am not sure what the differences were if any but it didn't require different parts or slow anything down. Like I stated... 1999 C2 chassis with a 2003 3.6 engine hooked up the original1999 gearbox and then later swapped for a 2003 gearbox.
Existing lightweight flywheel and clutch were transferred over for new gearbox.
Old 10-27-2010, 08:22 AM
the experts
we do these cars everday........i've been used to being the "testdummy" on mods in the past and am glad to see that you've beatn't me to the punch.
have a great deal on brand new gearbox and will go ahead and "fit" it in 00 car.....thanks-Mark
Old 10-27-2010, 09:03 AM
EBS_Don's Avatar
The only real differences are the gear ratios as these were made for the higher torque/HP 3.6 motors. The difference is fairly minor, however.
Don Weaver-EBS Racing
[email protected]
2006 Cayman S
'86 944T
'00 Boxster with EBS Racing 3.4 liter engine
Old 10-27-2010, 09:23 AM
The difference in gear ratios is so minor that it is non-existent.
There are absolutely no differences in gear ratios.
G96/00 and G96/01
1st gear: 3.82:1
2nd gear: 2:20:1
3rd gear: 1.52:1
4th gear: 1.22:1
5th gear: 1.02:1
6th gear: .84:1
Final: 3.44:1
Old 10-27-2010, 12:26 PM
EBS_Don's Avatar
Doh!! You're absolutely correct. I grabbed the wrong gear chart. In fact, all early 6 speeds including Box S have the same ratios!
[email protected]
2006 Cayman S
'86 944T
Old 10-27-2010, 02:12 PM
tail end fitment?
some have said in their rejection opinion that the physical differences at the nose of the 02 and later cause fitment problems that cannot allow u to get around?
I've seen both and cannot see such issues. basically, shouldn't it "bolt up" in a 00?
Old 10-27-2010, 04:14 PM
thank you for your information - now what kind of music do your guys like best
mine is trance
Old 11-02-2010, 03:10 AM
