screech at start-up
99 996
I've only had this car for a little bit, so I've got limited data I get a screech during startup. Very distinct conditions. Seems to be first thing in the morning -- haven't had it do it any other time of day. Only after the engine fires up -- starter does its 2-3 cranks, then screech -- immediately stops noise -- runs great. Don't notice any other noise -- sounds good -- only have a running boxster engine to compare too -- but they are essentially the same. Start it any time during the day -- even if having sat for several hours there is no screech. appreciate any pointers thanks, Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
This isn't specific to a 996, but whenever I hear a noise at startup that only occurs in the morning, I can usually relate it to morning dew or fog having settled on the belt(s) and pulleys. Do you park outside or inside? Does it get foggy where you park?
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
It most likely is the auxiliary air pump starting to go bad. It usually only runs for about 1 minute on cold startups.
the noise you describe sounds like your IMS chain tensioner is leaking oil overnight. A new updated tensioner has a preload spring to minimize chain "flap" until the tensioner builds oil pressure.
