996 power steering pump
Hi all,
1st Post so not sure what the procedure is ![]() Trying to get info or proceedure details as to change out the powersteering pump on a 2002 996. I have most of the parts out re; air filter, throttle body, power steering pump reservoir. Directly behind the pump there is one 13mm head bolt and I am having trouble with getting this off. Surely the mounting bracket which the power steering pump mounts to does not have to come off? Any advice or tricks and or links will be appreciatted. Thanks
I think you did great on your 1st post! It's been awhile since I removed a P/S pump but I remember it was a pain. Seems like you have to rotate it out.
