Guest
Posts: n/a
I have an early 996 1999, build 5/98 without a center radiator. Can I add the center radiator as you describe for the Boxster? What extra parts are required? What parts listed aren't needed? Any extra steps / pifalls?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Center Radiator Installation - - |
Author of "101 Projects"
Yes, the center radiator on the 996 installation is almost exactly the same as on the Boxster. The main differences are only in the pipe diameters on the Boxster - you don't have to mess with those. The pipe diameters should be larger on the 996, so that you don't need the reduction pieces described in the article.
- Wayne
