How did you install the plug for your trickle charger on your 997.1?
I guess there is no need to present the usual syndrome of the low/weak battery when you do not use your car every day.
I was thinking about installing a permanent set of wires connected to the battery and install a cigarette lighter type plug into one of the cooling openings under the headlight to easily plug in my charger without having to open the lid or leave a door/window ajar. What solution do you use to keep your car fully charged and ready to go in a jiffy? Thanks Yves Last edited by yvesvidal; 03-28-2011 at 12:18 PM.. |
On my 996, i use a "Battery Tender" (about $50 3 years ago) it came with a whip intended to connect to the battery and a mating plug with cap to connect to the cord from the tender. It is really easy to put the tender on it this way. I usually connect it at least once a month since the car is usually driven pretty often. It definitely helps.
The Porsche battery maintainer looks a lot like the Ctek product and connect via the cigarette lighter socket, which would seem to be even easier. I have seen the dealer close the door on the wire as it is pretty thin and it seems the door seals do not harm it. Not sure of the cost for this item.
Jeff '82SC Pacific Blue '02 C4S Silver (Gone but fondly remembered) '11 GTS Amethyst |
