Replacing AOS, is this the one?
Hi,
I am going to replace the infamous Air Oil Separator in my 2001 996 convertible. The car is smoking like it's burning, and the symptoms all point towards the AOS. Question is what I need to buy and where?
Only part I found here at Pelican is this one:
Pelican Parts - Product Information: 996-107-080-54-OEM
Or part no 996-107-080-54-OEM if the link doesn't work.
It looks cheaper than I would have anticipated, so I wanted to double check here before I order it.
Any advice would be very appreciated!
Thanks,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 07-21-2011, 08:11 AM
Does not look right. Maybe this one 996-107-023-55-M100 Oil Separator, 996 Carrera 2/4 (1999-01), Each
Brand: Genuine Porsche [More Info]
some DIYs
AOS 2002 Porsche 996 - Rennlist Discussion Forums
replace from top
So I replaced my Air/Oil separator - Rennlist Discussion Forums
Old 07-21-2011, 10:02 AM
KNS KNS is online now
Is the replacement AOS an improved part or will it eventually fail like the old one?
Kurt
Old 07-21-2011, 02:56 PM
They will all fail eventuality, it made up of plastic and rubber.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 07-21-2011, 04:19 PM
I believe it is an improved version but have never had to replace one. Google it and you should get a number of past posts on the subject that will confirm the changes made to the part over the years. The early versions were particularly prone to failure due to weaknesses in the design.
Old 07-21-2011, 04:42 PM
Thanks, that looks more like the right one. It's only one of them, right?
Regards,
Johan
Old 07-21-2011, 10:52 PM
1 of these per engine, behind driver on left drive cars.
Old 07-22-2011, 04:39 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Thanks,
Johan
Since you have a convertible, you already have less access to the engine from the top. To replace the AOS, you should drop the engine a few inches to increase access and also remove the coolant expansion tank and the driver's side manifold.
It's kind of tricky to replace. I jhave a write-up on how to do it. Email me and I'll send you the info.
[email protected]
Old 07-28-2011, 12:32 PM
