Climate Control Temp Dial
I recently acquired a 2005 (997) Carrera with 33K miles on the oddometer. I noticed that the black surface of the TEMP control dial seems to be peeling or chipping off, revealing the white surface beneath. Has anyone experienced a similar problem and if so, what might be the best way t go about restoring the black surface which appears to be slightly textured as opposed to a smooth finish?
Thank you for any help on this issue.
Old 11-01-2011, 06:09 AM
I have the same issue with my car. The dial has a rubberized coating that is common on all Porsche, VW and Audi cars recently. I have a Passat also with the same issue, but on all the dials and buttons. To replace to dial on a 997, I think it requires replacing the entire module, big bucks. My current solution, which is rather half azz but it works, is to use a Sharpie or permanent black marker to touch it up every now and then. It's not perfect, but it is better than the white plastic staring at me. I do recall, back from my early military days in the Army, there is a product we used on it brass eyelets of our black boots when the coating wore off. It was called M-Nue as I recall, tough as nails and very dark black. If I ever find some, I'll try that as well.
Mark Howard
Baton Rouge, Louisiana
2023 Taycan GTS
Old 11-05-2011, 06:28 AM
Thanks for the response Mark Howard. I will look into the black marker idea. I just have to be careful not to make it look worse. Replacement of the entire module would be the ideal soluton, but might result with the same deterioration over time, after spending the big bucks anyway.
Old 11-05-2011, 08:17 AM
I think Porsche has fixed the problem on the newer 997s. Perhaps it was just a bad batch.
Mark Howard
2023 Taycan GTS
Old 11-05-2011, 10:29 AM
