1999 996 C4 won't start
My wife was driving her C4 home from a 100 mile trip and it died about a mile from home (I know...thank goodness) She restarted it and it ran and drove for a few seconds, then died again. It started one more time only for an even shorter period and hasn't started since. I had it towed home thinking I would be able to figure it out. I got a Durametric tool and pulled the codes:
P1130 - Porsche Code 361 O2 sensing adaptation, idle range bank 2 P1128 - Porsche Code 360 O2 sensing adaptation, idle range bank 1 P0455 - Porsche Code 94 - Tank vent system (this is an ongoing issue, replaced cap twice) P1124 - Porsche Code 167 - Fuel Pump Relay, below limit value Because the code 167 was fuel related, I thought this was the culprit and replaced the Relay. No love. I still get the code after the replacement. It seems as though I can hear the fuel pump working when I turn the key, could it be that the fuel pump itself is not working like it should or perhaps the fuel pressure regulator? The car turns over fine, but will not fire. Any help would be appreciated...thanks. |
Hurdiguirdiman
A thought from the 'old school'..Fuel starvation could be a fuel pump failure or a blocked carborator. My two cents for what it's worth. Good luck.
