I have a 99 911 Cabriolet and the issue is with the final stages of cover closing. The last part of the sequence is for the cover to pull down over the top and then the dash light goes out. There are no issues with the top operation it is just the cover. The cover doesn't close the final 1" and if I start to raise the top and then reverse it to close, the cover will then close the final 1". (The dash light will otherwise blink if the cover doesn't fully close.) Does a hydraulic hose have a small leak and I'm low of fluid? Defective switch? What do you think? Thanks Bob
Check the fluid first.
Step by step DIY You will have to join to see it. Renntech.org is worth it for the DIYs, TSB, access to manuals etc.. http://www.renntech.org/forums/tutorials/article/56-cabrio-top-hydraulic-fluid-step-by-step/ It could be micro switch timing. In that case you will need to read/reset it with the dealers PWIS.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 11-28-2011 at 09:12 PM.. |
Thanks for tips! I hope to find time this weekend to check it out.
I narrowed down my problem to the passenger side flap. It was operating too slow to hit the last micro switch. I talked with the local Porche Dealer and they suggested to lube up the guide rails first (they can dry out and hang up over time). Things returned to normal operation which is a good thing because to replace the flap motor the entire top has to come out to access the motor (tons of labor!)
Good find. Always nice to fix it yourself and save $$ too.
