Brendan (guest)
Guest
Posts: n/a
I'm the original owner of a '99 996 Carrera manual shifter that experiences difficulty changing from 1st to 2nd, most prominently when the engine's cold. I live in Miami so the temp is pretty uniform throughout the year. I can almost always grate a few gear teeth tips if I shift slowly. The shifter used to be like butter when the car was new but over the past 5 years it's become much more difficult to change gears. I changed the transmission fluid recently with a synthetic but with no difference. Can anyone suggest either an appropriate grade/brand fluid or is the gearbox synchros damaged and require gearbox replacement?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 993 Technical Article:
Old 12-11-2011, 01:11 PM
Author of "101 Projects"
Wayne 962's Avatar
There is a problem with shifting on these cars, and a detent in the transmission that gets worn out. I have an article on this, but it's not published on the website quite yet. If you drop me an email, [email protected], I can email you what I have so far and the fix that we performed on our 996.
- Wayne
