Hurdiguirdiman
Has anyone ever noticed when doing a brake job, under normal braking or even track braking, which, if either set, front or rear brake pads, wear out more than the other? I just did a brake job on my 1999 C2 996 and only needed to replace the rear brake pads. Just wondered if this was normal. Can anyone shed light on this subject. Thanks.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Brake Pedal Switch Replacement / Clutch Pedal Switch Replacement - 986 / 987 |
Author of "101 Projects"
Yes, in general, the front brakes wear out much quicker than the rears because when you have heavy braking, you have what is commonly known as "weight" transfer to the front brakes. The best way of illustrating this is to think of a trick motorcyclist who slams on his brakes and makes the rear wheel come off the ground while braking. This is an exaggerated circumstance, but you can draw the analogy from this that under normal heavy braking, the rear of the car tends to lift, reducing the amount of weight on the rear (and thus the amount of braking).
- Wayne
