Help!!! I can't open the doors or trunk w/ key fob???
Hi guys i'm in a big bind... I drove the car last Saturday to go Christmas shopping and have all the wifes presents in the trunk. So i go out tonight to get them out to wrap and the key fob wont open the door or trunk??? The light on the remote is flashing but nothing!!! What to do.... Thanks
Stick the key in the door lock and turn it to unlock the car. Get into the car, put the key in the ign and turn it within ~20 seconds or the alarm will go off. Start the car and use the release lever/switch depending on year.
Your car may have "gone to sleep" after the week. If everything works after the above that is probably what happened. If not your remote may need a new battery or it could be broken. If you put new battery(s)in it and it still does not work you will need to buy a new key head and have it programmed at the dealer. Total ~$300. Sunset Porsche sells the head for ~$130. Portland Oregon Porsche Dealership - New & Used | SUNSET Porsche You will still need to get it programmed to the car. If you buy one on EBay or... make sure it comes with the 18 digit barcode label or it is useless. Some dealers will include the programming with the purchase, most will charge $125+ for programming.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 Last edited by FPB111; 12-23-2011 at 07:37 PM.. |
Did you get in? If your car battery is dead you need to hook up a battery to your car this is done by the fuse box drivers side inside the car. Check your manual. Good luck
yep, it was just sleeping!!! all is good and thanks for the help.
