996 Xenon Lights are they self leveling?
I am purchasing a 2004 996 and have heard stories about the Self Leveling headlights. How can I tell if my vehicle has these lights?
There's a self-test function...I think you start with the lights turned on and the ignition off, then start the ignition. The car has to be facing a wall or it should be dark out, so you can see the headlight beams. They should dip momentarily when you start the ignition, then come back up. Even if they do work, they still depend on a little arm connected to the front suspension to be connected, so check that too if you're not sure.
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
