Doing ims, rms, clutch anything else
While I'm in there, should I replace the AOS and associated lines/hoses? Car has 45k miles and haven't had any problems in this area. Was just thinking that it might be easier to access with trans out. How about the coolant expansion tank?
Old 04-19-2012, 09:19 AM
Yes.................
Old 04-19-2012, 11:16 AM
one of gods prototypes
bell's Avatar
make sure you get new flywheel bolts............
wouldn't hurt to change the gear oil.......
if it's a 2000 or later you'll need to drop the rear of the engine a bit to swap the expansion tank, kind of a pia unless you're dropping the whole engine.......
I would at least update the cap to the black one if it currently has a blue cap.
Brought to you by Carl's Jr.
Old 04-19-2012, 05:37 PM
DaveBerry's Avatar
What is the difference between the black and blue caps? I have a 2000 Carrera with a blue cap.
Old 04-20-2012, 07:53 AM
bell's Avatar
the blue caps prematurely start to vent, a telltale sign is coolant residue around it. biggest problem with this is the drain for the expansion tank usually moves and dumps onto coil pack #1, the result is a cracked coil and misfires if it's not caught. the black cap is the porsche update which seems to be the fix, I have seen this countless times at our shop, but being florida we probably see more than cooler climates.....i have seen black caps vent prematurely, but most every blue one I've seen fails.
you can easily move and secure the overflow drain tube away from coil 1.....
Old 04-20-2012, 06:36 PM
DaveBerry's Avatar
I looked at Pelican Parts for the new radiator cap:
All they show is a blue cap:
Pelican Parts - Product Information: 996-106-447-04-M100
Is this the fixed replacement cap?
Old 04-23-2012, 06:32 AM
