Taller tires for 996 C4S
Can you help me to find out wich are the taller tires that can fit my 2002 996 C4S?
actually it has 225-40-18 Front and 295-30-18 Rears. jCons |
Get the "original equipment" 17s then you can get taller sidewalls with the same dia as the 18s so you don't change the speedometer/odometer accuracy.
Check the tirerack site Sizes To Fit Your Vehicle
Do you know if these wheels will fit over the C4S larger discs?
How can I check that? thanks for your help. jCons |
Looks like it.
Look at the tire inflation guide on your car. See if it gives both 17" and 18" pressures. Original Equipment Sizes for 2002 Porsche 911 Carrera 4 Coupe Porsche equips your vehicle with more than one possible size during production. Please select the size installed on your vehicle from the choices below. Original Equipment Front Size 1: 205/50-17 Original Equipment Rear Size 1: 255/40-17 Original Equipment Front Size 2: 225/40-18 Original Equipment Rear Size 2: 285/30-18
You are right:
It came with size 2: 225-40-18 and 285-30-18 jCons |
Most folks give up the extra comfort and rim protection of the taller sidewall of the 17" for sharper turn in, harsher ride and greater possibility of pinched sidewalls/bent rims of the 18". (actually sharper handling, the rest is just a bonus)
You are completely right.
I will let the 18 inc wheels for Drivers Ed, and run the 17s everyday. A lot of thanks for your help Frank. Jorge Cons |
Don't know if you found 17s. Here is a guy selling some.
Rennlist Discussion Forums
