Metallic Clicking noise from rear wheel 996 Need Help
Have a metallic clicking noise at low speed from the rear back drivers side wheel of my 996 Turbo, this is what I have done so far.
Replaced discs & pads and mounting hardware, replaced e brake shoes, checked wheel for cracks, checked for something in tires, checked to see if heat shield was in contact with hub.
They car is lowered with H & R coilovers by 1 1/2",
Any help will be much appreciated the noise is on the driver side, 1 click every rotation driving me nuts......
Old 06-03-2012, 01:52 PM
Could it be a CV joint? I just discovered that the stub axel has a hole all of the way through the center into the joint. I don't run caps on the wheels since its s track only car and I just had one side rust up and start clicking. I hose the wheels off after every event and I'm guessing I rinsed the grease out.
Old 06-03-2012, 02:32 PM
DaveBerry's Avatar
The exact thing happened to me with my previous car, a G35. I had a metallic clicking sound, once per revolution. I only heard it at low speeds. I took it to my tire shop for an inspection. When they removed the tire from the wheel, they found the inside valve stem nut loose in the tire. When rotating slow, it hit the metallic rim once per revolution. At high speeds, it was forced to the outside by centrifugal force.
Old 06-06-2012, 07:35 AM
Going faster all the time
Litesonic's Avatar
I know it's a mundane thing... but did you check the center caps for "snugness"? Mine where a bit loose so I wrapped em (on the interface surface) with eletrical tape and pressed them back in with my hand. Now no rattle.
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 06-06-2012, 08:20 AM
