LFHUNT1
9 Quarts?
All:
Thanks in advance for your reply.... Just purchased a 2004 C4S. Changed the oil and replaced it w/ 9 quarts. Wow.... Its full! My question - Is it too full?? FYI, It currently shows right at the top of the required mark (after a 15 minute drive). Thoughts? Thanks, Lindsey Hunt |
Sound about right to me. My 996 manual states oil capacity of 9.3 quarts when replacing oil filter. When I add 9 quarts, the dash display is just below the top line. I add a wee bit more to bring it up to full. Do not want to overfill it!
9 quarts is correct. I burn one quart between oil changes. 7k miles.
You should use the dip stick for an accurate reading. The dash graph is ok but I think the dipstick reading is better. |
