Engine compatibility: 2WD vs 4WD
A friend is looking to replace a blown engine in his 4wd '99 996. He found a used 100Kmile '99 2WD with non-electronic throttle where his car has the electronic throttle. Is this an easy swap and fully compatible?
Any upgrades which should be done while out? I assume the LM Eng IMS upgrade.
Ed
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 10-15-2012, 05:06 AM
txhokie4life's Avatar
just switch the intakes, might have to swap the wiring harness
IMS upgrade, plugs, spark plug tube seals, maybe coil paks, maybe chain tensioners,
consider a low temp thermostat, inspect idler pulleys, consider swapping alt and starter
replace the AOS. Those kid of things.
mike
2001 996 GT2
Old 10-15-2012, 05:45 AM
