CEL Code P1128 and p1130
P1128 "oxygen sensing adaptation area 2 cyl 1-3 rich threshold"
P1130 "oxygen sensing range 2 adaptation bank 2"
This what I looked up somewhere, is it right?
Based on this can someone tell me which sensors need replacing? I know the simple thing to do would be replace them all ....but just asking!
2001 911 Carrera coupe 6 speed
Old 11-17-2012, 10:56 AM
Not likely one of the O2's. Make sure the Mass Air is clean. Make sure no vacuum leaks or exhaust leaks. Fuel pressure too high or a leaking injector but that would usually set a misfire code on that cylinder a P030X. EVAP purge valve can but should also set a P0445 code.
Hope that helps a bit.
Old 11-17-2012, 01:03 PM
So will a leaking hose at the fuel pump in the tank
Rob
Old 11-22-2012, 08:36 PM
