PPI Costs?
what are the normal costs associated with a PPI? i'm thinking they're around $100....is this right? are there different levels of inspection? never had one done before...thx
Old 12-16-2012, 06:27 AM
Hodgey's Avatar
Meares,
A good PPI is going to cost at least $300 depending on what you want inspecting.
3 years ago, my '87 cost $350 including leak down test and compression test.
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 12-16-2012, 06:58 AM
My quote for a PPI was $500 including leakdown and compression on a 964. They reduced the cost of subsequent service as I had them go from the PPI to fix everything needed, including a full tune up which would have included a compression/leakdown. I had them defer the more expensive parts of the review until they confrimed minimal other needs, and could have quit at the $2-3 hundred range if the car was failing due to items found based on drive/inspections.
8 Porsche's to date, after many years of looking 1999 C2 Cab, Ocean Blue over tan Leather.
Old 12-16-2012, 10:05 AM
be here now
R K T's Avatar
a hundred dollars would strictly be a "no touch" visual inspection.
Five hundred would be top notch inspection with leak down and comp.
Rob....
Old 12-17-2012, 02:53 PM
thx guys
Old 12-17-2012, 03:49 PM
I think most would agree,
$300 or $500 it is the best money spent.
I looked at one that needed a top end rebuild and was in a pretty bad accident but fixed, best money i ever spent to find that out. could have costed me more than the car....
Old 12-17-2012, 09:49 PM
autophiliac.wordpress.com
Drive the car - if it feels underpowered you'll know you need a full inspection to see what the issues are, if it runs/drives/feels good, you can usually be fine with a visual inspection on a lift.
Make sure you go to a shop that stakes their reputation on their work, and that you can trust - these kinds of shops don't cut corners and actually stand by their PPIs.
Old 01-02-2013, 02:20 PM
