intermix problem with 996
hello , i need some advice, i have 1999 996, few days ago i lost coolant in system, as i later fined out it got into oil, i bring car to Porsche center they think problem is oil cooling radiator, did anybody had such problem? do you know what it can be if not this radiator? can it be oil/air separator? please advice
Old 01-12-2013, 01:42 PM
Intermix issues caused by the oil cooler are not that uncommon. If it is the oil cooler, they can pull it and pressure test it to confirm.
Old 01-12-2013, 02:03 PM
one of gods prototypes
bell's Avatar
Its a good place to start.....if its not that it could be major...unfortunately.
Brought to you by Carl's Jr.
Old 01-12-2013, 02:32 PM
sorry to hear about your problem.
I wonder if I got lucky when I noticed a coolant leak.
http://forums.pelicanparts.com/porsche-996-997-forum/716942-coolant-top-right-cyl-bank.html?highlight=oil%2Fwater
What would have to be done to clean the water out of the engine?
Let us know what you find.
Good Luck, I hope the tab isn't to high
Old 01-13-2013, 08:19 AM
read this thread on how Darn55 fixed his.
Intermix/Cracked head repair - Rennlist Discussion Forums
Old 01-13-2013, 09:18 PM
Old 01-13-2013, 09:19 PM
Today I got new radiator, lets see how it will be, i cross my fingers.
Old 01-15-2013, 03:55 AM
Keep us posted.
Old 01-15-2013, 10:25 AM
let say so they are still testing, now it seams that we are losing Oil , oil level went down. is it normal? what it cam mean??
Old 01-16-2013, 02:12 AM
The oil cooler had about 1/2 qt in it when removed.
Old 01-16-2013, 10:52 AM
just to update, IT IS NOT RADIATOR, now we will disassemble Engine, will start with head as I was advised.
Old 01-21-2013, 12:31 AM
Use a bore scope to look into the cylinder thru the sparkplug hole for any cracks in the cylinders.
Old 01-21-2013, 08:15 AM
txhokie4life's Avatar
From a 3.6 -- Not sure how easy this would be to see from a boroscope -- but certainly worth the try.
2001 996 GT2
Old 01-22-2013, 03:17 PM
see post #6 for a common type of crack in the head. 1 - 3 side most often. These can be repaired. see post #5
Old 01-22-2013, 06:43 PM
I am Back, and again same problem, crack in the head, on first cylinder. exactly same as shown above, today I am taking it for welding lets see.
Old 01-25-2013, 12:28 AM
