Porsche-pa
75Carrera's Avatar
How do you get the light switch out??
I'm replacing several "wood" bits in my 996tt. Working on A/C vents right now. I got the passenger side installed easily. I'm stuck trying to get the driver's side A/C vent out. The light switch seems to be in there solidly. Is there a trick to getting it out? Help!
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 05-20-2013, 04:20 PM
one of gods prototypes
bell's Avatar
There is a tab on the underside of the switch, pull it out like you are turning on the fogs. Push it in with a small tipped tool and the” knob” will Pop off....its dead center underneath the knob...
Next.....and this you need to be careful with...
Use a long t20 and remove thetorx bit in the recess of the switch...you'll see a large thin nut around the switch center post, remove it...
This will let you remove the larger black plastic surround of the switch, there is a ribbon cable on it, so remove very carefully....
Brought to you by Carl's Jr.
Old 05-20-2013, 05:07 PM
Porsche-pa
75Carrera's Avatar
Thank you "bell"
Still working it out but looking doable now. This forum isn't as active as the 911 forum I have been on for years but I'm gaining ground discovering like minded owners and learning more daily about this latest addition to the stable.
Are you an administrator?
Donny
Also rans...
Donny
Old 05-20-2013, 07:17 PM
Very active 996 forum here
Porsche | 911 928 993 996 | Owners, Research, DIY, For Sale - Rennlist.com
Very good tech forum here. Well worth joining for the TSBs, Manuals, etc...
996 Series (Carrera, Carrera 4, Carrera 4S, Targa) - RennTech.org Forums
And of course here with pics,
Pelican Parts - Porsche 911 Carrera Technical Articles - Porsche 996 (1998-2004) & Porsche 997 (2005-2008)
Pelican Porsche Tech Article - Porsche 911 Carrera Headlamp Switch Replacement - Porsche 996 Carrera (1998-2005), Porsche 997 Carrera (2005-2008)
Old 05-21-2013, 10:58 AM
bell's Avatar
6speed online had some good info too....
I'm a Porsche wrench in Orlando, have been with an independent guru for 3+ years...
Old 05-21-2013, 07:26 PM
Porsche-pa
75Carrera's Avatar
Thanks Bell and Frank. I got the switch out. Not too difficult once you learn these little tricks. I visit Renlist and 6speed and have learned a bunch there as well. My air cooled 75 Carrera is bone simple compared to this 996tt, to say the least. Really enjoying the car and finding new friends on Pelican and the other sites.
Drive fast take chances....
Donny
Also rans...
Donny
Old 05-22-2013, 03:53 PM
