Guest
Posts: n/a
Excellent article on Tiptronic oil change. I have just checked under the car and I have the later unit post 2002 996 Targa. Your fig4 do you have the torque for the 6mm fill,drain screws and sump screws.
Thanks __________________ This post was auto-generated based upon a question asked on our tech article page here: |
I would grab a repair manual. It will list the special tools and each step of the procedure. Give our parts specialists a call: 1-888-280-7799 They will help you find what you need.
- Nick |
Transmission pan bolts: 7.3 ft-lb. Drain plug: 30 ft-lb. Fill plug: 59 ft-lb.
996 tiptronic sump
Many thanks, I must have an old manual as it only show to older type tipronic sump.
Tag10 |
Looking a the technical article again the fill plug torque of 59 ft lbs (80 Nm) is for the older sump. On the post 2002 sump the drain and fill plugs are the same smaller size therefore require far less torque?
tag10 |
You are correct, 2002 on the drain plug should be 16.2 ft.-lb.
